[postgis-devel] [PostGIS] #1797: validatetopology error when asking for column names
trac at osgeo.org
Tue May 1 09:17:32 PDT 2012
Reporter: jomarlla | Owner: strk
Type: defect | Status: new
Priority: low | Milestone: PostGIS 2.0.1
Component: topology | Version: 2.0.x
Keywords: |
Something is going wrong with the create temp table when one try to use
select (validatetopology ('t1')).*;
This is ok.
s9=# select validatetopology ('t1');
validatetopology
(0 rows)
now the error:
s9=# select (validatetopology ('t1')).*;
ERROR: relation "face_check" already exists
CONTEXT: SQL statement "CREATE TEMP TABLE face_check ON COMMIT DROP AS
SELECT face_id, topology.ST_GetFaceGeometry('t1', face_id) as geom, mbr
FROM t1.face WHERE face_id > 0"
PL/pgSQL function "validatetopology" line 204 at EXECUTE statement
Ticket URL: <https://trac.osgeo.org/postgis/ticket/1797>
