[postgis-devel] [PostGIS] #1797: validatetopology error when asking for column names
trac at osgeo.org
Thu May 3 01:54:41 PDT 2012
Reporter: jomarlla | Owner: strk
Type: defect | Status: new
Priority: low | Milestone: PostGIS 2.0.1
Component: topology | Version: 2.0.x
Keywords: |
Comment(by strk):
Ouch. I think this is due to what could be considered like a bug (IMHO) of
PostgreSQL, that is the fact that a set-returning function called with the
syntax: (srf()).* gets expanded as multiple calls to the function (one per
returning column) and results in actual calls rather than reusing the
result from the function (I think the function is STABLE).
So, since the function creates a temporary table, with transaction
lifetime, the second call finds the table already existing and bails out.
Not sure how could this be fixed, except maybe by avoiding the creation of
the temporary table (which would slow things down considerably).
Ticket URL: <https://trac.osgeo.org/postgis/ticket/1797#comment:1>
