[postgis-devel] [PostGIS] #1798: Performance issue with ST_Intersects(geometry, geometry)
PostGIS trac at osgeo.org
Thu May 3 02:50:00 PDT 2012
#1798: Performance issue with ST_Intersects(geometry,geometry)
 Reporter:  nicklas  |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.0.1
Component:  postgis  |     Version:  2.0.x
 Keywords:           |
Comment(by nicklas):
 You are right strk, it might be something we cannot control.
 But there is some strange things happening here, which I don't really
 understand.
 I will try to add a test case showing the effect.
 The question is if can detect if there is no working index and in case of
 that I think we shouldn't use prepared geometries in those cases.
 I will try to make the ticket more complete.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1798#comment:2>
