[postgis-devel] [PostGIS] #1798: Performance issue with ST_Intersects(geometry, geometry)
PostGIS trac at osgeo.org
Thu May 3 02:54:53 PDT 2012
#1798: Performance issue with ST_Intersects(geometry,geometry)
 Reporter:  nicklas  |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.0.1
Component:  postgis  |     Version:  2.0.x
 Keywords:           |
Comment(by strk):
 When switching to the "global cache" I think I noticed a different
 strategy within the two different caching strategies (rtree and prepared).
 One of them only built the cache/prepared after hitting the same polygon
 twice (never the first time). It should be checked for that policy to be
 consistent. In other words: check if the slower code path is always
 building the cache or only after seeing it twice.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1798#comment:3>
