[postgis-devel] [PostGIS] #1808: [raster] Raster importation creates gaps and corrupted data
trac at osgeo.org
Wed May 9 17:01:01 PDT 2012
Reporter: molgor | Owner: pramsey
Type: defect | Status: new
Priority: high | Milestone: PostGIS 2.0.1
Component: postgis | Version: 2.0.x
Keywords: |
Comment(by dustymugs):
I'm confused as to how you loaded your raster into PostGIS. Which one of
the following did you use to load that 2.1GB GeoTIFF file?
'''raster2pgsql'''
OR
'''QGIS raster loader plugin'''
If you used the command-line '''raster2pgsql''', please provide the
command line flags passed to '''raster2pgsql'''.
If you used the''' QGIS raster loader plugin''', you should use the
command-line '''raster2pgsql''' and see if it results in the same problem
as the QGIS raster loader plugin isn't directly supported by the PostGIS
raster devs.
Also, if you can post the output from running gdalinfo on your 2.1GB
GeoTIFF file, it can help us recreate the spatial characteristics of the
raster without knowing the data.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1808#comment:2>
