[postgis-devel] [PostGIS] #1808: [raster] Raster importation creates gaps and corrupted data
trac at osgeo.org
Wed May 9 17:12:57 PDT 2012
Reporter: molgor | Owner: pramsey
Type: defect | Status: new
Priority: high | Milestone: PostGIS 2.0.1
Component: postgis | Version: 2.0.x
Keywords: |
Comment(by molgor):
Yes, sure:
I used the command-line tool.
raster2pgsql -s 4326 -N -32767 -t 256x256 -I
pendiente_percent_regional_250m_wgs84.tif mapas.pendiente_percnt_256 >>
pendiente_perc_256.sql
And the gdalinfo exit for the loaded raster is this:
Driver: PostGISRaster/PostGIS Raster driver
Files: none associated
Size is 0, 0
Origin = (0.000000000000000,0.000000000000000)
Pixel Size = (1.000000000000000,1.000000000000000)
Subdatasets:
SUBDATASET_1_NAME=PG:host=localhost port=5432 dbname=incendios user=cpr
password=73 schema=mapas table=pendiente_percnt_256 column=rast
where='rid = 1'
SUBDATASET_1_DESC=PostGIS Raster at mapas.pendiente_percnt_256 (rast),
rid = 1
SUBDATASET_2_NAME=PG:host=localhost port=5432 dbname=incendios user=cpr
where='rid = 2'
SUBDATASET_2_DESC=PostGIS Raster at mapas.pendiente_percnt_256 (rast),
rid = 2
SUBDATASET_3_NAME=PG:host=localhost port=5432 dbname=incendios user=cpr
password=73 schema=mapas table=pendiente_percnt_256 column=rast where='rid
= 3'
SUBDATASET_3_DESC=PostGIS Raster at mapas.pendiente_percnt_256 (rast),
rid = 3
SUBDATASET_4_NAME=PG:host=localhost port=5432 dbname=incendios user=cpr
where='rid = 4'
SUBDATASET_4_DESC=PostGIS Raster at mapas.pendiente_percnt_256 (rast),
rid = 4
SUBDATASET_5_NAME=PG:host=localhost port=5432 dbname=incendios user=cpr
where='rid = 5'
SUBDATASET_5_DESC=PostGIS Raster at mapas.pendiente_percnt_256 (rast),
rid = 5
SUBDATASET_6_NAME=PG:host=localhost port=5432 dbname=incendios user=cpr
where='rid = 6'
SUBDATASET_6_DESC=PostGIS Raster at mapas.pendiente_percnt_256 (rast),
rid = 6
SUBDATASET_7_NAME=PG:host=localhost port=5432 dbname=incendios user=cpr
where='rid = 7'
SUBDATASET_8658_NAME=PG:host=localhost port=5432 dbname=incendios
user=cpr password=73 schema=mapas table=pendiente_percnt_256 column=rast
where='rid = 8658'
SUBDATASET_8658_DESC=PostGIS Raster at mapas.pendiente_percnt_256
(rast), rid = 8658
Corner Coordinates:
Upper Left ( 0.0000000, 0.0000000)
Lower Left ( 0.0000000, 0.0000000)
Upper Right ( 0.0000000, 0.0000000)
Lower Right ( 0.0000000, 0.0000000)
Center ( 0.0000000, 0.0000000)
This is the gdalinfo exit for the original image:
Driver: GTiff/GeoTIFF
Files: pendiente_percent_regional_250m_wgs84.tif
Size is 28368, 19839
Coordinate System is:
GEOGCS["WGS 84",
DATUM["WGS_1984",
SPHEROID["WGS 84",6378137,298.257223563,
AUTHORITY["EPSG","7030"]],
AUTHORITY["EPSG","6326"]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433],
AUTHORITY["EPSG","4326"]]
Origin = (-128.604911499087336,53.626968388905460)
Pixel Size = (0.002424431085498,-0.002424431085498)
Metadata:
AREA_OR_POINT=Area
Image Structure Metadata:
INTERLEAVE=BAND
Corner Coordinates:
Upper Left (-128.6049115, 53.6269684) (128d36'17.68"W, 53d37'37.09"N)
Lower Left (-128.6049115, 5.5286801) (128d36'17.68"W, 5d31'43.25"N)
Upper Right ( -59.8286505, 53.6269684) ( 59d49'43.14"W, 53d37'37.09"N)
Lower Right ( -59.8286505, 5.5286801) ( 59d49'43.14"W, 5d31'43.25"N)
Center ( -94.2167810, 29.5778242) ( 94d13' 0.41"W, 29d34'40.17"N)
Band 1 Block=28368x1 Type=Float32, ColorInterp=Gray
NoData Value=-32767
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1808#comment:3>
