[postgis-devel] [PostGIS] #1806: Extremely slow and CPU-intensive ST_MakeValid (ST_BuildArea) case
trac at osgeo.org
Sat May 12 11:18:44 PDT 2012
Reporter: strk | Owner: strk
Type: defect | Status: closed
Priority: high | Milestone: PostGIS 2.0.1
Component: postgis | Version: 2.0.x
Resolution: fixed | Keywords:
Comment(by hugoledoux):
@aperi2007: the polygon is actually invalid acc. to the OGC rules because
the inner ring (grey ring) separate the outer ring into 2 separate
polygons. The rules of the OGC state, among others, that the inteterior of
a polygon must be connected. The only solution is to split the polygon
into 2 polygons (which means that the inner ring disappears, indeed).
ST_MakeValid does not return per se a POLYGON, but a GEOMETRYCOLLECTION
which can contain a MULTIPOLYGON, to cope with these situations.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1806#comment:18>
