[postgis-devel] [PostGIS] #1806: Extremely slow and CPU-intensive ST_MakeValid (ST_BuildArea) case
trac at osgeo.org
Sat May 12 11:52:22 PDT 2012
Reporter: strk | Owner: strk
Type: defect | Status: closed
Priority: high | Milestone: PostGIS 2.0.1
Component: postgis | Version: 2.0.x
Resolution: fixed | Keywords:
Comment(by aperi2007):
>@aperi2007: the polygon is actually invalid acc. to the OGC rules because
the inner
>ring (grey ring) separate the outer ring into 2 separate polygons. The
rules of the
>OGC state, among others, that the inteterior of a polygon must be
connected.
Sorry, I forgot the connected rule.
The polygon is invalid.
>The only solution is to split the polygon into 2 polygons (which means
that the >inner ring disappears, indeed).
Of course this is the only valid solution.
>ST_MakeValid does not return per se a POLYGON, but a GEOMETRYCOLLECTION
which can >contain a MULTIPOLYGON, to cope with these situations.
Yes , the ST_MakeValid must try to maintain the original type when this is
possible.
In this sample this is not possible , so it will return a more complex
type.
Just as puntualize question:
the st_makevalid never return a set of records, it return always one only
record. If the geometry invalid is more complex, the MakeValid will
produce an unique geometrycollection with as many polygon or multipolygons
and/or lines and/or points to cover all the vertexs of the original
geometry.
The important is that is wll return always one only record.
Is this the strategy you follow also ?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1806#comment:19>
