[postgis-devel] [PostGIS] #1287: Drop of "gist_geometry_ops" broke a few clients
trac at osgeo.org
Wed May 16 07:51:27 PDT 2012
Reporter: strk | Owner: pramsey
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Resolution: wontfix | Keywords: history
Comment(by springmeyer):
as a note to other users that hit this problem, and find this ticket, it
appears possible to patch postgis 2.0 for back compatibility here.
You can add to your db the below sql to re-implement `gist_geometry_ops`
as identical to the new name of `gist_geometry_op_2d`.
The reason I am doing this is because osm2pgsql (while updated now to work
with postgis 2.0) has proved very difficult to get compiled and working on
windows (https://github.com/springmeyer/osm2pgsql). So, for windows users
I'm forging ahead with a method to get a 2 year old osm2pgsql working (the
last available windows binary) with postgis 2.0 on windows, and this was
the last piece of the puzzle after adding back srid 900913 and loading the
legacy.sql.
Happy to hear from the devs if this shim is a terrible idea and there
might be better ways to alias this.
CREATE OPERATOR CLASS gist_geometry_ops
FOR TYPE geometry USING GIST AS
STORAGE box2df,
OPERATOR 1 << ,
OPERATOR 2 &< ,
OPERATOR 3 && ,
OPERATOR 4 &> ,
OPERATOR 5 >> ,
OPERATOR 6 ~= ,
OPERATOR 7 ~ ,
OPERATOR 8 @ ,
OPERATOR 9 &<| ,
OPERATOR 10 <<| ,
OPERATOR 11 |>> ,
OPERATOR 12 |&> ,
OPERATOR 13 <-> FOR ORDER BY pg_catalog.float_ops,
OPERATOR 14 <#> FOR ORDER BY pg_catalog.float_ops,
FUNCTION 8 geometry_gist_distance_2d (internal,
geometry, int4),
FUNCTION 1 geometry_gist_consistent_2d (internal,
geometry, int4),
FUNCTION 2 geometry_gist_union_2d (bytea, internal),
FUNCTION 3 geometry_gist_compress_2d (internal),
FUNCTION 4 geometry_gist_decompress_2d (internal),
FUNCTION 5 geometry_gist_penalty_2d (internal,
internal, internal),
FUNCTION 6 geometry_gist_picksplit_2d (internal,
internal),
FUNCTION 7 geometry_gist_same_2d (geom1 geometry,
geom2 geometry, internal);
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1287#comment:8>
