[postgis-devel] [PostGIS] #1824: Installation on windows 64 failed
trac at osgeo.org
Tue May 22 03:57:23 PDT 2012
Reporter: pierrevandelaar | Owner: robe
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 2.0.1
Component: build/upgrade/install | Version: 2.0.x
Resolution: fixed | Keywords:
Comment(by robe):
I thought we had fixed the issue, but I guess not. I'll put a note on the
website site. Unfortunately anyone installing from stackbuilder is not
going to read it. I thought we were packaging the libxml2-2.dll so that
it would install on 9.1.2 and 9.0.5, but was hard to test since we don't
have those versions installed. I suspect that's a similar issue the ESRI
folks are running into since I think ESRI packages with 9.0.5 (instead of
9.0.6) which has the same issue as 9.1.2.
Anway thanks for the report. Goes a long way to helping others with
similar issue.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/1824#comment:8>
