[postgis-devel] [PostGIS] #1844: Function to drop TopoGeometry objects not found in their layers
trac at osgeo.org
Mon May 28 13:54:07 PDT 2012
Reporter: strk | Owner: strk
Type: enhancement | Status: new
Priority: medium | Milestone: PostGIS 2.1.0
Component: topology | Version: trunk
Keywords: |
It happens that TopoGeometry objects exist in the "relation" table but are
not reachable from their layer tables anymore. A simple DELETE or UPDATE
on the layer table could be the cause of this.
It would be useful to have a function to drop all such "orphaned" objects.
Not sure how to threat objects associated with non deployed or otherwise
invalid layers (layers for which the associated schema.table.column
doesn't exist).
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1844>
