[postgis-devel] [PostGIS] #2077: [raster] ST_Hillshade output can be wrong
trac at osgeo.org
Fri Nov 2 10:07:56 PDT 2012
Reporter: dustymugs | Owner: dustymugs
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.2
Component: raster | Version: 2.0.x
Keywords: |
The following doesn't return the correct answers.
WITH foo AS (
SELECT
ST_SetValue(
ST_SetValue(
ST_SetValue(
ST_SetValue(
ST_SetValue(
ST_SetValue(
ST_SetValue(
ST_SetValue(
ST_SetValue(
ST_AddBand(ST_MakeEmptyRaster(5,
5, 0, 0, 1, -1, 0, 0, 0), 1, '32BF', 1, -9999),
1, 2, 2, 2
1, 3, 2, 2
1, 4, 2, 2
1, 2, 3, 2
1, 3, 3, 3
1, 4, 3, 2
1, 2, 4, 2
1, 3, 4, 2
1, 4, 4, 2
) AS rast
), bar AS (
SELECT
ST_Slope(rast, 1, '32BF') AS slope,
ST_Aspect(rast, 1, '32BF') AS aspect,
ST_Hillshade(rast, 1, '32BF', 1.75 * pi(), pi() / 4) AS
hillshade
FROM foo
SELECT
x, y, val
FROM (
SELECT
(ST_PixelAsPolygons(hillshade)).*
FROM bar
) baz
results in
x | y | val
1 | 1 |
1 | 2 |
1 | 3 |
1 | 4 |
1 | 5 |
2 | 1 |
2 | 2 | 251.32763671875
2 | 3 | 220.749786376953
2 | 4 | 147.224319458008
2 | 5 |
3 | 1 |
3 | 2 | 220.749786376953
3 | 3 | 180.312225341797
3 | 4 | 67.7497863769531
3 | 5 |
4 | 1 |
4 | 2 | 147.224319458008
4 | 3 | 220.749786376953
4 | 4 | 43.1210060119629
4 | 5 |
5 | 1 |
5 | 2 |
5 | 3 |
5 | 4 |
5 | 5 |
(25 rows)
The value for 4x3 is incorrect.
The equivalent in ArcGIS Spatial Analyst's Hillshade tool with azimuth =
315 degrees and altitude = 45 degrees on the attached raster (same as what
is built in sql) looks like
NUL NUL NUL NUL NUL
NUL 251 220 147 NUL
NUL 220 180 67 NUL
NUL 147 67 43 NUL
NUL NUL NUL NUL NUL
The cell 4x3 should be 67, NOT 220.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2077>
