[postgis-devel] [PostGIS] #2119: [raster] use "substitute" SRS in RASTER_GDALWarp() when raster SRID = 0 AND function isn't being called to do a reprojection
PostGIS trac at osgeo.org
Fri Nov 30 05:01:24 PST 2012
  Reporter:  dustymugs    |       Owner:  dustymugs
      Type:  enhancement  |      Status:  closed
  Priority:  medium       |   Milestone:  PostGIS 2.1.0
 Component:  raster       |     Version:  trunk
Resolution:  fixed        |    Keywords:  history
Comment(by robe):
 Is #1293 still necessary with this change.  The only reason I needed
 resize was to get around the issue that I couldn't resize my purty land
 inspection pictures because they have no SRID but if resample now works
 without srid seems like a non-issue :)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2119#comment:3>
