[postgis-devel] [PostGIS] #2119: [raster] use "substitute" SRS in RASTER_GDALWarp() when raster SRID = 0 AND function isn't being called to do a reprojection
trac at osgeo.org
Fri Nov 30 07:09:11 PST 2012
Reporter: dustymugs | Owner: dustymugs
Type: enhancement | Status: closed
Priority: medium | Milestone: PostGIS 2.1.0
Component: raster | Version: trunk
Resolution: fixed | Keywords: history
Comment(by dustymugs):
I'm going to say yes just because I'm almost done with ST_Resize() :-).
Also, ST_Resample() is a big and bulky function (lots of possible
arguments) while ST_Resize() is much simpler...
CREATE OR REPLACE FUNCTION st_resize(
rast raster,
width text, height text,
algorithm text DEFAULT 'NearestNeighbour', maxerr double precision
DEFAULT 0.125
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2119#comment:4>
