[postgis-devel] [PostGIS] #2025: side location conflict at topogeo_AddLineString() of separate edges
PostGIS trac at osgeo.org
Tue Oct 2 01:59:44 PDT 2012
 Reporter:  wimned    |       Owner:  strk
     Type:  defect    |      Status:  new
 Priority:  medium    |   Milestone:  PostGIS 2.1.0
Component:  topology  |     Version:  trunk
 Keywords:            |
 Version I use:
 POSTGIS="2.1.0SVN r10195" GEOS="3.3.4-CAPI-1.7.3" PROJ="Rel. 4.7.1, 23
 September 2009" LIBXML="2.7.8" TOPOLOGY
 Currently I build up topologies in separate districts, each in their own
 schema. When I enter the resulting edges into a main topology I get this
 error.
 The message:
 ERROR:  GEOSContains: TopologyException: side location conflict at 2 4
 CONTEXT:  SQL statement "UPDATE wimpy.edge_data SET left_face = CASE WHEN
 left_face = 3 THEN 4 ELSE left_face END, right_face = CASE WHEN right_face
 = 3 THEN 4 ELSE right_face END WHERE ( left_face = 3 OR right_face = 3)
 AND NOT edge_id = ANY ('{6,3,5,2,5}') AND NOT
 ST_Contains('0103000020E6100000010000000D0000000000000000000040000000000000104000000000000000400000000000000840000000000000F03F0000000000000840000000000000F03F0000000000001040000000000000F03F00000000000014400000000000000040000000000000144000000000000000400000000000001040000000000000184000000000000000400000000000001C4000000000000000400000000000001C40000000000000F03F0000000000001840000000000000F03F0000000000001840000000000000004000000000000000400000000000001040'::geometry,
 geom)"
 PL/pgSQL function "_st_addfacesplit" line 114 at EXECUTE statement
 SQL statement "SELECT topology._ST_AddFaceSplit(atopology,
 newedge.edge_id, newedge.left_face, false)"
 PL/pgSQL function "st_addedgemodface" line 510 at SQL statement
 PL/pgSQL function "topogeo_addlinestring" line 124 at assignment
 SQL statement "SELECT topogeo_AddLineString('wimpy', line5)"
 The code:
 CREATE OR REPLACE FUNCTION testerror1()
  returns void as
     declare line1 geometry;
     declare line2 geometry;
     declare line3 geometry;
     declare line4 geometry;
     declare line5 geometry;
     declare line6 geometry;
     declare simpl_tol float;
 begin
     raise notice 'version: %', postgis_full_version();
     perform CreateTopology('wimpy', 4326, 0.0000001);
     simpl_tol = 0.00001;
     line1 = ST_GeometryFromText(
         'LINESTRING(0 0, 0 6,8 6,8 0,0 0)', 4326);
     line2 = ST_GeometryFromText(
         'LINESTRING(6 2,7 2,7 1,6 1,6 2)', 4326);
     line3 = ST_GeometryFromText(
         'LINESTRING(1 4,1 5,2 5,2 4)', 4326);
     line4 = ST_GeometryFromText(
         'LINESTRING(2 4,1 4)', 4326);
     line5 = ST_GeometryFromText(
         'LINESTRING(2 4,2 3,1 3,1 4)', 4326);
     line6 = ST_GeometryFromText(
         'LINESTRING(6 2,2 4)', 4326);
     perform topogeo_AddLineString('wimpy', line1);
     perform topogeo_AddLineString('wimpy', line2);
     perform topogeo_AddLineString('wimpy', line3);
     perform topogeo_AddLineString('wimpy', line4);
     perform topogeo_AddLineString('wimpy', line6);
     perform topogeo_AddLineString('wimpy', line5);
 END
 LANGUAGE plpgsql;
 When I insert line 5 before line 6 I don't get the error.
 Also validatetopology() doesn't report errors then.
 I understand that line 6 breaks proper polygon topology here, but it is
 part of a face being built up.
 When I have to AddLineString the complete polygon rings, I'll loose  the
 performance gain I have by building up in separate districts
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2025>
