[postgis-devel] [PostGIS] #2025: side location conflict at topogeo_AddLineString() of separate edges
trac at osgeo.org
Tue Oct 2 07:15:16 PDT 2012
Reporter: wimned | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.1.0
Component: topology | Version: trunk
Keywords: |
Comment(by strk):
Putting image inline for discussion.
[[Image(topo_err.jpg)]]
So you're basically getting a side-location conflict when adding line 5
after line 6, right ?
Could you attach another image showing the topology with all lines but 6
inserted ?
Also add output of TopologySummary to make sure we see all the nodes and
the edges.
And ideally insert a scale too, so that we can see how big 0.0000001 is
(your tolerance).
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2025#comment:1>
