[postgis-devel] [PostGIS] #2025: side location conflict at topogeo_AddLineString() of separate edges
PostGIS trac at osgeo.org
Tue Oct 2 07:21:57 PDT 2012
 Reporter:  wimned    |       Owner:  strk
     Type:  defect    |      Status:  new
 Priority:  medium    |   Milestone:  PostGIS 2.1.0
Component:  topology  |     Version:  trunk
 Keywords:            |
Comment(by strk):
 I'm attaching it. This is the topology still valid before attempt to add
 edge 5.
 The smallest distance you can see is the square side, which is 1.0.
 I can reproduce the problem even with NO tolerance.
 [[Image(before_five.png)]]
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2025#comment:2>
