[postgis-devel] [PostGIS] #2025: side location conflict at topogeo_AddLineString() of separate edges
trac at osgeo.org
Tue Oct 2 07:31:21 PDT 2012
Reporter: wimned | Owner: strk
Type: defect | Status: assigned
Priority: medium | Milestone: PostGIS 2.1.0
Component: topology | Version: trunk
Keywords: |
Changes (by strk):
* status: new => assigned
Comment:
The "AND NOT ST_Contains" query is from topology._ST_AddFaceSplit.
I'm pretty sure the function could be improved to avoid full containment
check,
given we know there's no edge crossing.
You're the best tester wimned, thanks a lot !
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2025#comment:3>
