[postgis-devel] [PostGIS] #2024: raster: ST_Union is buggy
trac at osgeo.org
Wed Oct 3 22:33:34 PDT 2012
Reporter: robe | Owner: dustymugs
Type: defect | Status: closed
Priority: blocker | Milestone: PostGIS 2.1.0
Component: raster | Version: trunk
Resolution: fixed | Keywords:
Comment(by robe):
I'll have to retest #1659 (I'll do that in next day or so). False alarm
on the speed. In the prior test I was testing my 9.2.1 EDB install and
since my 9.2.0 mingw 64 uses the same port, I launched that one by
accident. That one is evidentally a bit slower (about 500 ms slower for
test I was running) than the VC++ build. I should have know since I didn't
have the test database I had created on it. Not sure if it's because I
haven't upgraded it to 9.2.1 or it's mingw or I have different settings on
it. Anyway 9.2.1 EDB shows about the same speed as before.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2024#comment:20>
