[postgis-devel] [PostGIS] #2024: raster: ST_Union is buggy
PostGIS trac at osgeo.org
Thu Oct 4 07:56:15 PDT 2012
  Reporter:  robe     |       Owner:  dustymugs
      Type:  defect   |      Status:  closed
  Priority:  blocker  |   Milestone:  PostGIS 2.1.0
 Component:  raster   |     Version:  trunk
Resolution:  fixed    |    Keywords:
Comment(by pracine):
 I think you should test with images bigger than the one you used in your
 blog (i.e. a SRTM tile?). Note also that the size of the tiles affect the
 performance. The same image tiled smaller should take longer to be
 unioned. And the most important is: Is the time required still progress as
 the square of the number of pixel involved? If yes then you should soon
 reach astronomic times as the size of your image grow.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2024#comment:21>
