[postgis-devel] [PostGIS] #2041: installation.xml does not follow the DTD
trac at osgeo.org
Fri Oct 12 00:29:34 PDT 2012
Reporter: strk | Owner: robe
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.1.0
Component: documentation | Version: trunk
Keywords: |
On make check under doc (do the bots run this?):
installation.xml:619: element sect2: validity error : Element sect2
content does not follow the DTD, expecting (sect2info? , (title ,
subtitle? , titleabbrev?) , (toc | lot | index | glossary | bibliography)*
, (((calloutlist | glosslist | bibliolist | itemizedlist | orderedlist |
segmentedlist | simplelist | variablelist | caution | important | note |
tip | warning | literallayout | programlisting | programlistingco | screen
| screenco | screenshot | synopsis | cmdsynopsis | funcsynopsis |
classsynopsis | fieldsynopsis | constructorsynopsis | destructorsynopsis |
methodsynopsis | formalpara | para | simpara | address | blockquote |
graphic | graphicco | mediaobject | mediaobjectco | informalequation |
informalexample | informalfigure | informaltable | equation | example |
figure | table | msgset | procedure | sidebar | qandaset | task | anchor |
bridgehead | remark | highlights | abstract | authorblurb | epigraph |
indexterm | beginpage)+ , (refentry* | sect3* | simplesect*)) | refentry+
| sect3+ | simplesect+) , (toc | lot | index | glossary | bibliography)*),
got (title para para command para para programlisting para para
itemizedlist para para programlisting para para programlisting warning
para para para programlisting )
</sect2>
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2041>
