[postgis-devel] [PostGIS] #2041: installation.xml does not follow the DTD
trac at osgeo.org
Fri Oct 12 00:31:21 PDT 2012
Reporter: strk | Owner: robe
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.1.0
Component: documentation | Version: trunk
Keywords: |
Comment(by strk):
Ouch, can't you use <command> in a <para> ? I did in r10409 to fix
duplicated "make comments" tag (<programlisting> and <command>)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2041#comment:1>
