[postgis-devel] Fwd: ST_DumpPoints in C
Sandro Santilli
strk at keybit.net
Mon Oct 15 10:54:44 PDT 2012
What's the URI to clone from ?
It isn't clear from the web
Also, if you're getting up to speed with git, what about pushing
your merge of it into a temporary branch published somewhere on
for us to test more easily ?
--strk;
On Mon, Oct 15, 2012 at 10:34:21AM -0700, Paul Ramsey wrote:
> FYI, there's a C implementation of dumppoints available for testing.
> If it's OK w/ y'all I'll pull it into trunk. Let me know.
> P.
> ---------- Forwarded message ----------
> From: Nathan Wagner <nw at hydaspes.if.org>
> Date: Sat, Oct 13, 2012 at 11:43 PM
> Subject: Re: ST_DumpPoints in C
> To: Paul Ramsey <pramsey at opengeo.org>
> Available via anonymous git clone at
> https://pd.if.org/git/dumppoints
> The usual gitweb interface is there which you can browse as well.
> nw
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
http://www.cartodb.com - Map, analyze and build applications with your data
~~ http://strk.keybit.net
