[postgis-devel] Fwd: ST_DumpPoints in C
Paul Ramsey
pramsey at opengeo.org
Mon Oct 15 11:00:29 PDT 2012
It's not mine, it's Nathan's...
the URL to clone is
https://pd.if.org/git/dumppoints
and it's not a patch on PostGIS, it's an extension that depends on PostGIS
P.
On Mon, Oct 15, 2012 at 10:54 AM, Sandro Santilli <strk at keybit.net> wrote:
> What's the URI to clone from ?
> It isn't clear from the web
> Also, if you're getting up to speed with git, what about pushing
> your merge of it into a temporary branch published somewhere on
> for us to test more easily ?
> --strk;
> On Mon, Oct 15, 2012 at 10:34:21AM -0700, Paul Ramsey wrote:
>> FYI, there's a C implementation of dumppoints available for testing.
>> If it's OK w/ y'all I'll pull it into trunk. Let me know.
>> P.
>> ---------- Forwarded message ----------
>> From: Nathan Wagner <nw at hydaspes.if.org>
>> Date: Sat, Oct 13, 2012 at 11:43 PM
>> Subject: Re: ST_DumpPoints in C
>> To: Paul Ramsey <pramsey at opengeo.org>
>> Available via anonymous git clone at
>> The usual gitweb interface is there which you can browse as well.
>> nw
>> postgis-devel mailing list
>> postgis-devel at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
> http://www.cartodb.com - Map, analyze and build applications with your data
> ~~ http://strk.keybit.net
