[postgis-devel] [PostGIS] #1976: ST_Intersects() returns false while ST_Intersection returns a geography
trac at osgeo.org
Wed Sep 5 11:18:59 PDT 2012
Reporter: mhiper3pg | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 1.5.6
Component: postgis | Version: 1.5.X
Keywords: |
When running ST_Intersects() with multipolygons, sometimes ST_Intersects()
returns false for the intersection, while ST_Intersection() returns a
geography (not empty).
How to reproduce: loading the geography for the state of Iowa (attached)
in a table (with no indexes), and querying for the intersection with a
polygon fully contained in the state:
select st_intersects(geog, ST_GeographyFromText('SRID=4326;POLYGON((-95.9
42.9,-95.9 43,-95.8 43,-95.8 42.9,-95.9 42.9))')),
st_astext(st_intersection(geog,ST_GeographyFromText('SRID=4326;POLYGON((-95.9
42.9,-95.9 43,-95.8 43,-95.8 42.9,-95.9 42.9))'))) from states where
name10='Iowa'
yields this result:
st_intersects |
st_astext
f | POLYGON((-95.9 42.8999999999999,-95.9
42.9999999999999,-95.8 42.9999999999999,-95.8 42.8999999999999,-95.9
42.8999999999999))
(1 row)
So, the query with ST_Intersects() returns false (which is wrong), but
using ST_Intersection() provides the correct result.
Is this behavior normal?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1976>
