[postgis-devel] [PostGIS] #1976: ST_Intersects() returns false while ST_Intersection returns a geography
PostGIS trac at osgeo.org
Wed Sep 5 11:48:25 PDT 2012
  Reporter:  mhiper3pg  |       Owner:  pramsey
      Type:  defect     |      Status:  closed
  Priority:  medium     |   Milestone:  PostGIS 1.5.6
 Component:  postgis    |     Version:  1.5.X
Resolution:  invalid    |    Keywords:
Changes (by pramsey):
  * status:  new => closed
  * resolution:  => invalid
Comment:
 There are many things going on here.
 First, probably ST_Intersects is actually *right*, the polygon does
 intersect Iowa, see http://blog.opengeo.org/2012/04/30/the-earth-is-not-
 flat-volume-2/ for an explanation.
 Second, because ST_Intersection is not actually running in spherical
 coordinates (it's a cheater wrap to a planar projection) the results are
 not consistent with ST_Intersects, which *is* running in spherical.
 In all, I think I need to either make the planar hack more sophisticated
 (rathole) or start thinking about how to do constructive geometry on the
 sphere (ratmine).
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1976#comment:1>
