[postgis-devel] [PostGIS] #1979: TopoGeo_AddLinestring: return duplicated edge id, misses a created edge id
trac at osgeo.org
Thu Sep 6 02:39:44 PDT 2012
Reporter: amartin | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.2
Component: topology | Version: 2.0.x
Keywords: |
Comment(by amartin):
The behavior can be reproduced with only two components
SELECT TopoGeo_AddLineString('my_topo',indiv_geom, 0.8)
FROM (SELECT (ST_Dump(p_geom)).geom as indiv_geom
FROM (SELECT ST_GeomFromText('MULTILINESTRING ((535695.149659
4352913.865809, 535688.723014 4352898.92539, 535723.74701 4352895.150892,
535753.102703 4352892.178469, 535795.04699 4352887.189505, 535796.627126
4352887.671191, 535833.621825 4352884.315548, 535876.015985
4352880.471036), (535688.497742 4352897.353794, 535688.721074
4352898.927358, 535695.149659 4352913.865809))',25830) AS p_geom) AS
geom_squery) AS lines;
Still getting duplicate edge_ids and a newly created edge_id is unreported
Query result:
"topogeo_addlinestring"
"50"
"52"
"50"
my_topo.edge_data table:
edge_id
50
51
52
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1979#comment:3>
