[postgis-devel] [PostGIS] #1979: TopoGeo_AddLinestring: return duplicated edge id, misses a created edge id
PostGIS trac at osgeo.org
Thu Sep 6 02:52:15 PDT 2012
 Reporter:  amartin   |       Owner:  strk
     Type:  defect    |      Status:  new
 Priority:  medium    |   Milestone:  PostGIS 2.0.2
Component:  topology  |     Version:  2.0.x
 Keywords:            |
Comment(by strk):
 See if you can also reduce the number of vertices, and eventually also
 round some up (it'll be harder to round up as this is likely a robustness
 issue).
 Also, it's better to have 2 separate queries to precisely control order
 (order does matter).
 Would also improve readability (and you can better inspect what's there
 after insertion of the first edge and better read the debugging line on
 second call).
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1979#comment:4>
