[postgis-devel] [PostGIS] #1990: Inconsistent X/Y coordinates swapping in GML
trac at osgeo.org
Mon Sep 10 15:08:58 PDT 2012
Reporter: xificurk | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.2
Component: postgis | Version: 2.0.x
Keywords: |
ST_AsGML always outputs coordinates in order X,Y.
=> SELECT st_asgml(st_setsrid(st_makepoint(15, 50), 4326), 15, 0);
<gml:Point
srsName="EPSG:4326"><gml:coordinates>15,50</gml:coordinates></gml:Point>
=> SELECT st_asgml(st_setsrid(st_makepoint(15, 50), 4326), 15, 1);
<gml:Point
srsName="urn:ogc:def:crs:EPSG::4326"><gml:coordinates>15,50</gml:coordinates></gml:Point>
=> SELECT st_asgml(st_setsrid(st_makepoint(15, 50), 4326), 15, 16);
<gml:Point
On the other hand, ST_GeomFromGML swaps coordinates, if given srsName in
format like 'urn:ogc:def:crs:EPSG::4326' instead of simple 'EPSG:4326'.
Although the examples use 4326 SRS, it does not depend on this exact
setting.
=> SELECT st_astext(st_geomfromgml('<gml:Point
xmlns:gml="http://www.opengis.net/gml/3.2"
srsName="urn:ogc:def:crs:EPSG::4326"><gml:coordinates>15,50</gml:coordinates></gml:Point>'));
POINT(50 15)
ruian=> SELECT st_astext(st_geomfromgml('<gml:Point
srsName="EPSG:4326"><gml:coordinates>15,50</gml:coordinates></gml:Point>'));
POINT(15 50)
Tested on 64bit Gentoo setup with fresh postgis install on top of
PostgreSQL 9.1.5.
POSTGIS="2.0.1 r9979" GEOS="3.3.3-CAPI-1.7.4" PROJ="Rel. 4.8.0, 6 March
2012" LIBXML="2.8.0"
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1990>
