[postgis-devel] [PostGIS] #2005: Some images have an L multipoint overlaid
trac at osgeo.org
Tue Sep 18 00:26:03 PDT 2012
Reporter: robe | Owner: robe
Type: defect | Status: new
Priority: high | Milestone: PostGIS 2.1.0
Component: documentation | Version: trunk
Keywords: |
Comment(by strk):
Last time I looked at the generate.c file it was pretty much betting on
sizes, so could be a memory error...
I noticed that the L you see is the one you have in the second
DelaunayTriangles example.
Also (off-topic): wouldn't it make more sense to only show points as the
input of DelaunayTriangles ? After all whatever you pass in, only the
vertices will be used as input...
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2005#comment:1>
