[postgis-devel] AddRasterConstraints failing to create extents in raster_column view
ryagz raghavendra at vizexperts.com
Tue Apr 16 18:46:29 PDT 2013
I have very large table of about 50GB, while uploading to database i am
dividing the images into tiles and uploading them as rows in the table.
After inserting all the data i am Creating index, AddingRasterConstraints
and respective overview constraints.
The problem i am facing is AddRasterConstraints function is some times not
creating extents in the raster_column view. While loading back the data i am
trying to use raster_columns table to get the raster information so as to
speed up the loading process. So, it is very important for me that
AddRasterConstraints returns appropriate values. Can you please let me know
wat could the problem possibly be and any information on how to debug and
fix the problem is highly appreciated.
Other problem i would like to report is, AddRasterConstraints is taking too
much time. For the table mentioned above which has 64x64 tile in each row
and 2263390 rows in the table it took about 3850 sec which was about 20% of
total upload time(19440 sec). Is AddRasterConstraints expected to take so
long? if so is there any way to optimize it?
Thanks in advance.
Ryagz
View this message in context: http://postgis.17.x6.nabble.com/AddRasterConstraints-failing-to-create-extents-in-raster-column-view-tp5003029.html
Sent from the PostGIS - Dev mailing list archive at Nabble.com.
