[postgis-devel] Memory context question
Stephen Woodbridge woodbri at swoodbridge.com
Tue Apr 23 07:32:58 PDT 2013
Hi Guys,
I have created the function below. At the end of the function I add a
new standardizer to my cache. As part of doing this I need to copy the
table names and attach them to the cache entry and do this with pstrdup().
Because pstrdup() does a palloc(), I think this needs to be done in the
memory context of the cache entry. Am I correct in assuming that I
should do a MemoryContextSwitchTo(STDMemoryContext) before the pstrdup()
and then switch back to the old_context afterwards?
static void
AddToStdPortalCache(StdPortalCache *STDCache, char *lextab, char
*gaztab, char *rultab)
     MemoryContext STDMemoryContext;
     STANDARDIZER *std = NULL;
     std = CreateStd(lextab, gaztab, rultab);
     if (!std)
         elog(ERROR,
             "AddToStdPortalCache: could not create address standardizer
for '%s', '%s', '%s'", lextab, gaztab, rultab);
     /* if the NextSlot in the cache is used, then delete it */
     if (STDCache->StdCache[STDCache->NextSlot].std != NULL) {
         StdCacheItem *ci = &STDCache->StdCache[STDCache->NextSlot];
         DBG("Removing item from STD cache ('%s', '%s', '%s') index %d",
ci->lextab, ci->gaztab, ci->rultab, STDCache->NextSlot);
         DeleteNextSlotFromStdCache(STDCache);
     DBG("Adding item to STD cache ('%s', '%s', '%s') index %d", lextab,
gaztab, rultab, STDCache->NextSlot);
     STDMemoryContext = MemoryContextCreate(T_AllocSetContext, 8192,
                                            &StdCacheContextMethods,
                                            STDCache->StdCacheContext,
                                            "PAGC STD Memory Context");
     /* Create the backend hash if it doesn't already exist */
     if (!StdHash)
         StdHash = CreateStdHash();
      * Add the MemoryContext to the backend hash so we can
      * clean up upon portal shutdown
     DBG("Adding standardizer obj (%p) to hash table with MemoryContext
key (%p)", std, STDMemoryContext);
     AddStdHashEntry(STDMemoryContext, std);
     // TODO: do we need to change memory context before the pstrdup ????
     STDCache->StdCache[STDCache->NextSlot].lextab = pstrdup(lextab);
     STDCache->StdCache[STDCache->NextSlot].gaztab = pstrdup(gaztab);
     STDCache->StdCache[STDCache->NextSlot].rultab = pstrdup(rultab);
     STDCache->StdCache[STDCache->NextSlot].std = std;
     STDCache->StdCache[STDCache->NextSlot].std_mcxt = STDMemoryContext;
     STDCache->NextSlot = (STDCache->NextSlot + 1) % STD_CACHE_ITEMS;
