[postgis-devel] Memory context question
Paul Ramsey pramsey at cleverelephant.ca
Tue Apr 23 09:46:59 PDT 2013
Yes, you have to be in the memory context you want the allocated memory to live in. I like to do all my allocations in once place so there's only one context switch, but there's you reason you can't do it as often as you like.
Paul Ramsey
http://cleverelephant.ca/
http://postgis.net/
On Tuesday, 23 April, 2013 at 7:32 AM, Stephen Woodbridge wrote:
> Hi Guys,
> I have created the function below. At the end of the function I add a
> new standardizer to my cache. As part of doing this I need to copy the
> table names and attach them to the cache entry and do this with pstrdup().
> Because pstrdup() does a palloc(), I think this needs to be done in the
> memory context of the cache entry. Am I correct in assuming that I
> should do a MemoryContextSwitchTo(STDMemoryContext) before the pstrdup()
> and then switch back to the old_context afterwards?
> static void
> AddToStdPortalCache(StdPortalCache *STDCache, char *lextab, char
> *gaztab, char *rultab)
> MemoryContext STDMemoryContext;
> STANDARDIZER *std = NULL;
> std = CreateStd(lextab, gaztab, rultab);
> if (!std)
> elog(ERROR,
> "AddToStdPortalCache: could not create address standardizer
> for '%s', '%s', '%s'", lextab, gaztab, rultab);
> /* if the NextSlot in the cache is used, then delete it */
> if (STDCache->StdCache[STDCache->NextSlot].std != NULL) {
> StdCacheItem *ci = &STDCache->StdCache[STDCache->NextSlot];
> DBG("Removing item from STD cache ('%s', '%s', '%s') index %d",
> ci->lextab, ci->gaztab, ci->rultab, STDCache->NextSlot);
> DeleteNextSlotFromStdCache(STDCache);
> DBG("Adding item to STD cache ('%s', '%s', '%s') index %d", lextab,
> gaztab, rultab, STDCache->NextSlot);
> STDMemoryContext = MemoryContextCreate(T_AllocSetContext, 8192,
> &StdCacheContextMethods,
> STDCache->StdCacheContext,
> "PAGC STD Memory Context");
> /* Create the backend hash if it doesn't already exist */
> if (!StdHash)
> StdHash = CreateStdHash();
> * Add the MemoryContext to the backend hash so we can
> * clean up upon portal shutdown
> DBG("Adding standardizer obj (%p) to hash table with MemoryContext
> key (%p)", std, STDMemoryContext);
> AddStdHashEntry(STDMemoryContext, std);
> // TODO: do we need to change memory context before the pstrdup ????
> STDCache->StdCache[STDCache->NextSlot].lextab = pstrdup(lextab);
> STDCache->StdCache[STDCache->NextSlot].gaztab = pstrdup(gaztab);
> STDCache->StdCache[STDCache->NextSlot].rultab = pstrdup(rultab);
> STDCache->StdCache[STDCache->NextSlot].std = std;
> STDCache->StdCache[STDCache->NextSlot].std_mcxt = STDMemoryContext;
> STDCache->NextSlot = (STDCache->NextSlot + 1) % STD_CACHE_ITEMS;
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org (mailto:postgis-devel at lists.osgeo.org)
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
