[postgis-devel] PostGIS 2.1.0beta3 build issues on Ubuntu 13.04
maplabs at light42.com
Fri Aug 2 10:21:27 PDT 2013
On Mon, 24 Jun 2013 23:24:30 1200, Mike Toews wrote:
I'm drafting up some build instructions for PostGIS 2.1 (beta3) on
Ubuntu 13.04:
http://trac.osgeo.org/postgis/wiki/UsersWikiPostGIS21Ubuntu1304src
However, I'm running into some linking problems related to "gdal-config
--dep-libs" that don't happen with PostGIS 2.0.3 on the same system
(which does not appear to call "gdal-config --dep-libs"). It seems that
the GDAL library linking flags don't work as expected with the gdal-dev
package, which I've submitted here:
https://bugs.launchpad.net/ubuntu/ source/gdal/ bug/1194082
I'm no linking expert, but does raster2pgsql now require linking to
GDAL's dependencies? It does not appear to require these With PostGIS
2.0, e.g.
x--
Hi Mike -
I do not have the asnwer to all challenges here, but I do want to
make you aware of a recent development. There is a package repository
for Ubuntu, called UbuntuGIS (based on DebianGIS, but slightly
different) In order to install a full suite of OSGeo.org tools, a
Google Summer of Code student, '''jlarouche''' has completed a number
of new packages (we are now using them on the upcoming OSGeo Live 7.0)
In particular, I call your attention to '''libgdal1h''' from
UbuntuGIS-unstable. I *strongly encourage* those interested in
packaging and documentation to consider this the new standard for
building the Ubuntu GIS tool set, including PostGIS 2.x. This is new
work, but testing has shown good results. I am not by any means a
packaging expert, but I wanted to let you know about this, so the
community can work through the remaining issues.
in order to add UbuntuGIS-unstable to your repoisitories, you can
add this to your /etc/apt/sources.list.d/
deb http://ppa.launchpad.net/ubuntugis/ubuntugis-unstable/ubuntu main
referring to this page
http://trac.osgeo.org/ubuntugis/wiki/UbuntuGISRepository
hth
Brian M Hamlin
OSGeo California Chapter
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20130802/5ac71f23/attachment.html>
