[postgis-devel] GEOS 3.4.1 is out
Devrim GÜNDÜZ
devrim at gunduz.org
Tue Aug 20 02:36:34 PDT 2013
On Tue, 2013-08-20 at 10:50 +0200, Sandro Santilli wrote:
> Did you build ruby bindings successfully with precedent GEOS
> versions ?
Yes:
http://yum.postgresql.org/9.3/redhat/rhel-6-x86_64/repoview/letter_g.group.html
3.3.8 just built fine.
> You are explicitly enabling those buildings, right ?
Yes:
http://svn.pgrpms.org/browser/rpm/redhat/9.3/geos/EL-6/geos.spec#L73
(If the page does not load properly, please reload)
> Bindings were recently updated to support ruby 1.9.x, with a patch
> from Kashif Rasul (in CC). I don't use those bindings myself so can't
> help much with those.
Something must be broken -- Kashif, can you please jump in? This is a
blocked for PostGIS 2.1.0 RPMs.
That said, I started to worry about GEOS release process -- 3.4.0 was
broken, 3.4.1 cannot be built on Red Hat/Fedora...
Regards,
Devrim GÜNDÜZ
Principal Systems Engineer @ EnterpriseDB: http://www.enterprisedb.com
PostgreSQL Danışmanı/Consultant, Red Hat Certified Engineer
Community: devrim~PostgreSQL.org, devrim.gunduz~linux.org.tr
http://www.gunduz.org Twitter: http://twitter.com/devrimgunduz
Desc: This is a digitally signed message part
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20130820/5c7cdc39/attachment.sig>
