[postgis-devel] GEOS 3.4.1 is out
Kashif Rasul
kashif.rasul at gmail.com
Tue Aug 20 02:39:52 PDT 2013
yes so i am checking as well, just to let you know whats going on:
we use the `macros/ruby.m4` to populate the appropriate env. variables, in particular:
RUBY_SO_NAME=`$RUBY -rrbconfig -e 'puts RbConfig::CONFIG[["LIBRUBY_SO"]] || Config::CONFIG[["RUBY_SO_NAME"]]'`
which we use in the `swig/ruby/Makefile.am`:
geos_la_LIBADD = $(top_builddir)/capi/libgeos_c.la -l$(RUBY_SO_NAME)
So I am checking if something is wrong there for your particular ruby version… hope to find something soon
best wishes!
kashif
Kashif Rasul
Sent with Sparrow (http://www.sparrowmailapp.com/?sig)
On Tuesday, August 20, 2013 at 11:36 AM, Devrim GÜNDÜZ wrote:
> Hi,
> On Tue, 2013-08-20 at 10:50 +0200, Sandro Santilli wrote:
> > Did you build ruby bindings successfully with precedent GEOS
> > versions ?
> Yes:
> http://yum.postgresql.org/9.3/redhat/rhel-6-x86_64/repoview/letter_g.group.html
> 3.3.8 just built fine.
> > You are explicitly enabling those buildings, right ?
> Yes:
> http://svn.pgrpms.org/browser/rpm/redhat/9.3/geos/EL-6/geos.spec#L73
> (If the page does not load properly, please reload)
> > Bindings were recently updated to support ruby 1.9.x, with a patch
> > from Kashif Rasul (in CC). I don't use those bindings myself so can't
> > help much with those.
> Something must be broken -- Kashif, can you please jump in? This is a
> blocked for PostGIS 2.1.0 RPMs.
> That said, I started to worry about GEOS release process -- 3.4.0 was
> broken, 3.4.1 cannot be built on Red Hat/Fedora...
> Regards,
> Devrim GÜNDÜZ
> Principal Systems Engineer @ EnterpriseDB: http://www.enterprisedb.com
> PostgreSQL Danışmanı/Consultant, Red Hat Certified Engineer
> Community: devrim~PostgreSQL.org (http://PostgreSQL.org), devrim.gunduz~linux.org.tr
> http://www.gunduz.org Twitter: http://twitter.com/devrimgunduz
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20130820/7ec5d1ea/attachment.html>
