[postgis-devel] SFCGAL
Sandro Santilli strk at keybit.net
Thu Dec 5 01:11:41 PST 2013
On Wed, Dec 04, 2013 at 10:05:03PM -0500, Stephen Mather wrote:
> Never mind.  I should set all my posts to users and dev to a 2 hour delay
> so I can answer them myself without echoing it out into cyberspace.
> Anyway, found the flag with a grep -r, so I added to the docs via github.
> I don't know if this is the best way, so yell if this is the wrong way
> 'round.
> https://github.com/postgis/postgis/pull/16
It's fine, as long as nobody pushes the "merge" button :)
Next time you could use the "git request-pull" command directly
and paste the output in here, or (even better) into a trac
ticket.
--strk;
