[postgis-devel] SFCGAL
Stephen Mather
mather.stephen at gmail.com
Thu Dec 5 05:20:48 PST 2013
:). Will do.
Sent from my iPod
On Dec 5, 2013, at 4:11 AM, Sandro Santilli <strk at keybit.net> wrote:
> On Wed, Dec 04, 2013 at 10:05:03PM -0500, Stephen Mather wrote:
>> Never mind. I should set all my posts to users and dev to a 2 hour delay
>> so I can answer them myself without echoing it out into cyberspace.
>> Anyway, found the flag with a grep -r, so I added to the docs via github.
>> I don't know if this is the best way, so yell if this is the wrong way
>> 'round.
>> https://github.com/postgis/postgis/pull/16
> It's fine, as long as nobody pushes the "merge" button :)
> Next time you could use the "git request-pull" command directly
> and paste the output in here, or (even better) into a trac
> ticket.
> --strk;
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
