[postgis-devel] 2.0.3 ?
Bborie Park
dustymugs at gmail.com
Thu Feb 28 10:39:26 PST 2013
Raster has no blockers for 2.0.x. + 1 by me.
On Thu, Feb 28, 2013 at 10:37 AM, Sandro Santilli <strk at keybit.net> wrote:
> I've fixed a memory fault in GeoJSON parser today,
> worth putting out a new release in the 2.0.3 IMHO.
> Does anyone have pending blockers ?
> Changes so far:
> * Bug Fixes *
> - #2126, Better handling of empty rasters from ST_ConvexHull()
> - #2134, Make sure to process SRS before passing it off to GDAL functions
> - Fix various memory leaks in liblwgeom
> - #2173, Fix robustness issue in splitting a line with own vertex
> also affecting topology building (#2172)
> - #2174, Fix usage of wrong function lwpoly_free()
> - #2176, Fix robustness issue with ST_ChangeEdgeGeom
> - #2184, Properly copy topologies with Z value
> - postgis_restore.pl support for mixed case geometry column name in dumps
> - #2188, Fix function parameter value overflow that caused problems
> when copying data from a GDAL dataset
> - #2216, More memory errors in MultiPolygon GeoJSON parsing (with holes)
> - Fix Memory leak in GeoJSON parser
> * Enhancements *
> - #2141, More verbose output when constraints fail to be added
> to a raster column
> - Speedup ST_ChangeEdgeGeom
> --strk;
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
