[postgis-devel] 2.0.3 ?
Sandro Santilli
strk at keybit.net
Thu Feb 28 10:37:40 PST 2013
I've fixed a memory fault in GeoJSON parser today,
worth putting out a new release in the 2.0.3 IMHO.
Does anyone have pending blockers ?
Changes so far:
* Bug Fixes *
- #2126, Better handling of empty rasters from ST_ConvexHull()
- #2134, Make sure to process SRS before passing it off to GDAL functions
- Fix various memory leaks in liblwgeom
- #2173, Fix robustness issue in splitting a line with own vertex
also affecting topology building (#2172)
- #2174, Fix usage of wrong function lwpoly_free()
- #2176, Fix robustness issue with ST_ChangeEdgeGeom
- #2184, Properly copy topologies with Z value
- postgis_restore.pl support for mixed case geometry column name in dumps
- #2188, Fix function parameter value overflow that caused problems
when copying data from a GDAL dataset
- #2216, More memory errors in MultiPolygon GeoJSON parsing (with holes)
- Fix Memory leak in GeoJSON parser
* Enhancements *
- #2141, More verbose output when constraints fail to be added
to a raster column
- Speedup ST_ChangeEdgeGeom
--strk;
