[postgis-devel] Loading Raster Overviews with gdal
dustymugs
dustymugs at gmail.com
Thu Jan 24 09:33:53 PST 2013
You'll want to use GDAL 1.10 (currently in beta). The performance issue
is in the PostGIS Raster driver in GDAL.
-bborie
On 01/24/2013 08:22 AM, ryagz wrote:
> Hi,
> I am trying to load postgis raster into an application which *gdal*. The
> loading performance is very poor if i directly load base raster. So, i have
> created overviews for the base image using raster2pgsql as bellow:
> raster2pgsql -s 4236 -I -t 256x256 -l 2,4,8,16,32.64,128,256,512 -F
> E:\test_data\doda1.tiff -d raster_test.doda_256x256_ov10 | psql.exe -U
> postgres -d postgis -h localhost -p 5432
> When i check in pgadmin, all the overviews are created properlyi. Now when i
> load the raster again into the application using the base image
> "doda_256x256_ov10" again, the performance remains the same. I am not clear
> which table name should be given to the application so that the application
> interactively switches between the overviews as i zoom in and zoom out.
> Kindly let me know wat could be done so as to improve my performance for
> zooming in and zooming out.
> Ryagz
> View this message in context: http://postgis.17.n6.nabble.com/Loading-Raster-Overviews-with-gdal-tp5002420.html
> Sent from the PostGIS - Dev mailing list archive at Nabble.com.
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
