[postgis-devel] 2.0.4 ?
Paul Ramsey pramsey at cleverelephant.ca
Tue Jul 2 12:46:41 PDT 2013
I'll look at the GEOS support in configuration, since we're going to have to cross that bridge probably.
P
Paul Ramsey
http://cleverelephant.ca/
http://postgis.net/
On Wednesday, 26 June, 2013 at 9:35 AM, Sandro Santilli wrote:
> I got the testcase, but I shall notice that PostGIS build scripts
> are currently using a single digit for each version component of GEOS,
> so releasing 3.3.9 will force us to change that as soon as we need
> to support 3.3.10 :)
> Add to it that there are currently 13 open tickets with milestone
> GEOS 3.3.9:
> http://trac.osgeo.org/geos/query?status=assigned&status=new&status=reopened&order=priority&col=id&col=summary&col=status&col=type&col=priority&col=milestone&col=component&milestone=3.3.9
> I think it takes more time before getting it out of the door.
> --strk;
> On Wed, Jun 26, 2013 at 02:14:20PM +0200, Sandro Santilli wrote:
> > On Wed, Jun 26, 2013 at 03:39:12AM -0400, Paragon Corporation wrote:
> > > Strk it would be nice if you released GEOS 3.3.9 first don't you think :)
> > For packagers ? Possibly.
> > I was +1 on PostGIS 2.0.4 because it wasn't ME having to do it :)
> > A GEOS-3.3.9 could be done, but I'm waiting for a testcase about
> > HotPixel code first.
> > --strk;
> > > -----Original Message-----
> > > From: postgis-devel-bounces at lists.osgeo.org (mailto:postgis-devel-bounces at lists.osgeo.org)
> > > [mailto:postgis-devel-bounces at lists.osgeo.org] On Behalf Of Sandro Santilli
> > > Sent: Wednesday, June 26, 2013 3:26 AM
> > > To: PostGIS Development Discussion
> > > Subject: Re: [postgis-devel] 2.0.4 ?
> > > On Tue, Jun 25, 2013 at 03:35:25PM -0700, Paul Ramsey wrote:
> > > > It's been 3 months since the last 2.0 point release and a moderate number
> > > of fixes have built up, anyone object to a 2.0 patch release?
> > > Changes, for the record:
> > > PostGIS 2.0.4
> > > 2013/MM/DD
> > > * Bug Fixes *
> > > - #2110, Equality operator between EMPTY and point on origin
> > > - Allow adding points at precision distance with TopoGeo_addPoint
> > > - #1968, Fix missing edge from toTopoGeom return
> > > - #2201, ST_GeoHash wrong on boundaries
> > > - #2257, GBOX variables not initialized when testing with empty geometries
> > > - #2271, Prevent parallel make of raster
> > > - #2267, Server crash from analyze table
> > > - #2277, potential segfault removed
> > > - Fix build with systemwide liblwgeom installed
> > > * Enhancements *
> > > - #2269, Avoid uselessly detoasting full geometries on ANALYZE
> > > +1 for me to release 2.0.4
> > > --strk;
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org (mailto:postgis-devel at lists.osgeo.org)
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
