[postgis-devel] 2.0.4 ?
Paul Ramsey
pramsey at cleverelephant.ca
Thu Jul 4 16:00:27 PDT 2013
I committed handling for two-digit version numbers through all our
operative branches (1.5+) and trunk, so we should be OK as GEOS
continue to rev up.
P
On Tue, Jul 2, 2013 at 12:46 PM, Paul Ramsey <pramsey at cleverelephant.ca> wrote:
> I'll look at the GEOS support in configuration, since we're going to have to cross that bridge probably.
> P
> Paul Ramsey
> http://cleverelephant.ca/
> http://postgis.net/
> On Wednesday, 26 June, 2013 at 9:35 AM, Sandro Santilli wrote:
>> I got the testcase, but I shall notice that PostGIS build scripts
>> are currently using a single digit for each version component of GEOS,
>> so releasing 3.3.9 will force us to change that as soon as we need
>> to support 3.3.10 :)
>> Add to it that there are currently 13 open tickets with milestone
>> GEOS 3.3.9:
>> http://trac.osgeo.org/geos/query?status=assigned&status=new&status=reopened&order=priority&col=id&col=summary&col=status&col=type&col=priority&col=milestone&col=component&milestone=3.3.9
>> I think it takes more time before getting it out of the door.
>> --strk;
>> On Wed, Jun 26, 2013 at 02:14:20PM +0200, Sandro Santilli wrote:
>> > On Wed, Jun 26, 2013 at 03:39:12AM -0400, Paragon Corporation wrote:
>> > > Strk it would be nice if you released GEOS 3.3.9 first don't you think :)
>> > For packagers ? Possibly.
>> > I was +1 on PostGIS 2.0.4 because it wasn't ME having to do it :)
>> > A GEOS-3.3.9 could be done, but I'm waiting for a testcase about
>> > HotPixel code first.
>> > --strk;
>> > > -----Original Message-----
>> > > From: postgis-devel-bounces at lists.osgeo.org (mailto:postgis-devel-bounces at lists.osgeo.org)
>> > > [mailto:postgis-devel-bounces at lists.osgeo.org] On Behalf Of Sandro Santilli
>> > > Sent: Wednesday, June 26, 2013 3:26 AM
>> > > To: PostGIS Development Discussion
>> > > Subject: Re: [postgis-devel] 2.0.4 ?
>> > > On Tue, Jun 25, 2013 at 03:35:25PM -0700, Paul Ramsey wrote:
>> > > > It's been 3 months since the last 2.0 point release and a moderate number
>> > > of fixes have built up, anyone object to a 2.0 patch release?
>> > > Changes, for the record:
>> > > PostGIS 2.0.4
>> > > 2013/MM/DD
>> > > * Bug Fixes *
>> > > - #2110, Equality operator between EMPTY and point on origin
>> > > - Allow adding points at precision distance with TopoGeo_addPoint
>> > > - #1968, Fix missing edge from toTopoGeom return
>> > > - #2201, ST_GeoHash wrong on boundaries
>> > > - #2257, GBOX variables not initialized when testing with empty geometries
>> > > - #2271, Prevent parallel make of raster
>> > > - #2267, Server crash from analyze table
>> > > - #2277, potential segfault removed
>> > > - Fix build with systemwide liblwgeom installed
>> > > * Enhancements *
>> > > - #2269, Avoid uselessly detoasting full geometries on ANALYZE
>> > > +1 for me to release 2.0.4
>> > > --strk;
>> postgis-devel mailing list
>> postgis-devel at lists.osgeo.org (mailto:postgis-devel at lists.osgeo.org)
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
