[postgis-devel] 2.0.4 ?
Paul Ramsey
pramsey at cleverelephant.ca
Fri Jul 5 09:45:15 PDT 2013
I applied it to everything, 1.5, 2.0, 2.1, trunk
Paul Ramsey
http://cleverelephant.ca
http://postgis.net
On Thursday, July 4, 2013 at 9:51 PM, Paragon Corporation wrote:
> You did for 2.1 branch as well. Remember trunk is 2.2.
> Also please backport to 2.1 for this:
> http://trac.osgeo.org/postgis/ticket/2307 if its necessary to do so.
> -----Original Message-----
> From: postgis-devel-bounces at lists.osgeo.org (mailto:postgis-devel-bounces at lists.osgeo.org)
> [mailto:postgis-devel-bounces at lists.osgeo.org] On Behalf Of Paul Ramsey
> Sent: Thursday, July 04, 2013 7:00 PM
> To: PostGIS Development Discussion
> Subject: Re: [postgis-devel] 2.0.4 ?
> I committed handling for two-digit version numbers through all our operative
> branches (1.5+) and trunk, so we should be OK as GEOS continue to rev up.
> P
> On Tue, Jul 2, 2013 at 12:46 PM, Paul Ramsey <pramsey at cleverelephant.ca (mailto:pramsey at cleverelephant.ca)>
> wrote:
> > I'll look at the GEOS support in configuration, since we're going to have
> to cross that bridge probably.
> > P
> > Paul Ramsey
> > http://cleverelephant.ca/
> > http://postgis.net/
> > On Wednesday, 26 June, 2013 at 9:35 AM, Sandro Santilli wrote:
> > > I got the testcase, but I shall notice that PostGIS build scripts are
> > > currently using a single digit for each version component of GEOS, so
> > > releasing 3.3.9 will force us to change that as soon as we need to
> > > support 3.3.10 :)
> > > Add to it that there are currently 13 open tickets with milestone
> > > GEOS 3.3.9:
> > > http://trac.osgeo.org/geos/query?status=assigned&status=new&status=re
> > > opened&order=priority&col=id&col=summary&col=status&col=type&col=prio
> > > rity&col=milestone&col=component&milestone=3.3.9
> > > I think it takes more time before getting it out of the door.
> > > --strk;
> > > On Wed, Jun 26, 2013 at 02:14:20PM +0200, Sandro Santilli wrote:
> > > > On Wed, Jun 26, 2013 at 03:39:12AM -0400, Paragon Corporation wrote:
> > > > > Strk it would be nice if you released GEOS 3.3.9 first don't you
> > > > > think :)
> > > > For packagers ? Possibly.
> > > > I was +1 on PostGIS 2.0.4 because it wasn't ME having to do it :)
> > > > A GEOS-3.3.9 could be done, but I'm waiting for a testcase about
> > > > HotPixel code first.
> > > > --strk;
> > > > > Sandro Santilli
> > > > > Sent: Wednesday, June 26, 2013 3:26 AM
> > > > > On Tue, Jun 25, 2013 at 03:35:25PM -0700, Paul Ramsey wrote:
> > > > > > It's been 3 months since the last 2.0 point release and a
> > > > > > moderate number
> > > > > of fixes have built up, anyone object to a 2.0 patch release?
> > > > > Changes, for the record:
> > > > > PostGIS 2.0.4
> > > > > 2013/MM/DD
> > > > > * Bug Fixes *
> > > > > - #2110, Equality operator between EMPTY and point on origin
> > > > > - Allow adding points at precision distance with TopoGeo_addPoint
> > > > > - #1968, Fix missing edge from toTopoGeom return
> > > > > - #2201, ST_GeoHash wrong on boundaries
> > > > > - #2257, GBOX variables not initialized when testing with empty
> > > > > geometries
> > > > > - #2271, Prevent parallel make of raster
> > > > > - #2267, Server crash from analyze table
> > > > > - #2277, potential segfault removed
> > > > > - Fix build with systemwide liblwgeom installed
> > > > > * Enhancements *
> > > > > - #2269, Avoid uselessly detoasting full geometries on ANALYZE
> > > > > +1 for me to release 2.0.4
> > > > > --strk;
> > > _______________________________________________
> > > postgis-devel mailing list
> > > postgis-devel at lists.osgeo.org (mailto:postgis-devel at lists.osgeo.org)
> > > http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
