[postgis-devel] Review of TWKB spec
maplabs at light42.com maplabs at light42.com
Wed Jun 19 13:08:02 PDT 2013
On Wed, 19 Jun 2013 19:00:39  0200, Even Rouault
<even.rouault at mines-paris.org> wrote:
* I would drop the bit for endianness. Just state that the endianness
is little endian, and let the few big endian hosts in the wild do the
byte swapping. This will make implementation of the spec easier.
* use the bit that has been saved above to indicate if the geometries
have an id or not. There are certainly use cases where we don't need
the id, or where it is transported by other means.
dbb> in the interest of simple (read bug free) implemenation, is it
really worth a bit to turn on and off the presence of the geometry ID ?
Brian M Hamlin
OSGeo California Chapter
