[postgis-devel] PostGIS 2.1.0beta3 build issues on Ubuntu 13.04
Bborie Park dustymugs at gmail.com
Mon Jun 24 15:32:28 PDT 2013
See if your build works by commenting out line 1057 of configure.ac
with "dnl". So, change configure.ac with
dnl LIBGDAL_DEPLIBS_LDFLAGS=`$GDAL_CONFIG --dep-libs`
And then run ./autogen.sh to rebuild the configure script.
-bborie
On Mon, Jun 24, 2013 at 3:17 PM, Mike Toews <mwtoews at gmail.com> wrote:
> On 25 June 2013 02:43, Bborie Park <dustymugs at gmail.com> wrote:
>> Hey Mike,
>> raster2pgsql requires whatever GDAL requires. That is how linking
>> works. Since raster2pgsql requires GDAL, libtool pulls in everything
>> that GDAL requires.
> Again, I'm pretty far from a linking expert, but I can't say I'm convinced
> that the dependant libraries also need to be linked, unless functions from
> these dependencies are used by raster2pgsql. Mapserver used to use
> --dep-libs, but found the linking unnecessary and removed this feature:
> http://trac.osgeo.org/mapserver/changeset/11618
> I suspect --dep-libs is not needed with shared libraries of GDAL, e.g. ldd
> libgdal.so will show it is already linked with its dependants at runtime,
> thus shouldn't need any further linking. However, I'm not sure if statically
> linked libraries should be considered differently.
> -Mike
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
