[postgis-devel] PostGIS 2.1.0beta3 build issues on Ubuntu 13.04
Mike Toews
mwtoews at gmail.com
Tue Jun 25 01:01:34 PDT 2013
On 25 June 2013 10:32, Bborie Park <dustymugs at gmail.com> wrote:
> See if your build works by commenting out line 1057 of configure.ac
> with "dnl". So, change configure.ac with
> dnl LIBGDAL_DEPLIBS_LDFLAGS=`$GDAL_CONFIG --dep-libs`
> And then run ./autogen.sh to rebuild the configure script.
Both 2.2 (trunk) and the 2.1 branch build successfully without GDAL's
dep-libs (as does the 2.0 branch, which never used it). Both 2.1 and 2.2
pass all the regression tests, except for a non-raster related test, which
I'll elaborate in a separate email.
-Mike
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20130625/c82fbf75/attachment.html>
