[postgis-devel] PostGIS beta1 is out but..... Stay tuned for beta2
Bborie Park
dustymugs at gmail.com
Sat May 11 18:54:35 PDT 2013
Regina,
>From what I can, shp2pgsql and pgsql2shp both have had dependencies on
GEOS for some time. I tested r11202 (2013-03-24 20:14:49 -0700) and
that has the dependency.
Time to see exactly which commit started the failures.
-bborie
On Sat, May 11, 2013 at 6:25 PM, Paragon Corporation <lr at pcorp.us> wrote:
> Some folks may have noticed that I already tagged a beta1. In the process
> of packaging, I discovered a problem which will necessitate a beta2 release
> soon. So hold off until I have that ready.
> It appears that liblwgeom has an unhealthy relationship with geos which is
> causing our documentation wkt image generator to not able to compile and
> thus not rebuld autogenerated images. On top of that I discovered my built
> packages for shp2pgsql-gui and I believe shp2pgsql/pgsql2shp now have a
> dependency on GEOs
> Which while not absolutely horrible, is not ideal either.
> Thanks,
> Regina
> http://postgis.net
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
