[postgis-devel] PostGIS beta1 is out but..... Stay tuned forbeta2
Bborie Park
dustymugs at gmail.com
Sat May 11 19:14:37 PDT 2013
Yep. Checking each revision shows that that patch broke things.
Rearranging is probably a good idea.
-bborie
On Sat, May 11, 2013 at 7:08 PM, Paragon Corporation <lr at pcorp.us> wrote:
> I know which commit broke it
> http://trac.osgeo.org/postgis/changeset/11361
> I'm working on getting rid of the include and moving the goes parts to ggeos
> files.
> See my note:
> http://trac.osgeo.org/postgis/ticket/1898#comment:23
> -----Original Message-----
> From: postgis-devel-bounces at lists.osgeo.org
> [mailto:postgis-devel-bounces at lists.osgeo.org] On Behalf Of Bborie Park
> Sent: Saturday, May 11, 2013 9:55 PM
> To: PostGIS Development Discussion
> Subject: Re: [postgis-devel] PostGIS beta1 is out but..... Stay tuned
> forbeta2
> Regina,
> From what I can, shp2pgsql and pgsql2shp both have had dependencies on GEOS
> for some time. I tested r11202 (2013-03-24 20:14:49 -0700) and that has the
> dependency.
> Time to see exactly which commit started the failures.
> -bborie
> On Sat, May 11, 2013 at 6:25 PM, Paragon Corporation <lr at pcorp.us> wrote:
>> Some folks may have noticed that I already tagged a beta1. In the
>> process of packaging, I discovered a problem which will necessitate a
>> beta2 release soon. So hold off until I have that ready.
>> It appears that liblwgeom has an unhealthy relationship with geos
>> which is causing our documentation wkt image generator to not able to
>> compile and thus not rebuld autogenerated images. On top of that I
>> discovered my built packages for shp2pgsql-gui and I believe
>> shp2pgsql/pgsql2shp now have a dependency on GEOs Which while not
>> absolutely horrible, is not ideal either.
>> Thanks,
>> Regina
>> http://postgis.net
>> postgis-devel mailing list
>> postgis-devel at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
