[postgis-devel] PostGIS beta1 is out but..... Stay tuned forbeta2
Bborie Park
dustymugs at gmail.com
Sat May 11 19:46:15 PDT 2013
Yep. r11438 works for me. You might still be a C developer!
-bborie
On Sat, May 11, 2013 at 7:14 PM, Bborie Park <dustymugs at gmail.com> wrote:
> Yep. Checking each revision shows that that patch broke things.
> Rearranging is probably a good idea.
> -bborie
> On Sat, May 11, 2013 at 7:08 PM, Paragon Corporation <lr at pcorp.us> wrote:
>> I know which commit broke it
>> http://trac.osgeo.org/postgis/changeset/11361
>> I'm working on getting rid of the include and moving the goes parts to ggeos
>> files.
>> See my note:
>> http://trac.osgeo.org/postgis/ticket/1898#comment:23
>> -----Original Message-----
>> From: postgis-devel-bounces at lists.osgeo.org
>> [mailto:postgis-devel-bounces at lists.osgeo.org] On Behalf Of Bborie Park
>> Sent: Saturday, May 11, 2013 9:55 PM
>> To: PostGIS Development Discussion
>> Subject: Re: [postgis-devel] PostGIS beta1 is out but..... Stay tuned
>> forbeta2
>> Regina,
>> From what I can, shp2pgsql and pgsql2shp both have had dependencies on GEOS
>> for some time. I tested r11202 (2013-03-24 20:14:49 -0700) and that has the
>> dependency.
>> Time to see exactly which commit started the failures.
>> -bborie
>> On Sat, May 11, 2013 at 6:25 PM, Paragon Corporation <lr at pcorp.us> wrote:
>>> Some folks may have noticed that I already tagged a beta1. In the
>>> process of packaging, I discovered a problem which will necessitate a
>>> beta2 release soon. So hold off until I have that ready.
>>> It appears that liblwgeom has an unhealthy relationship with geos
>>> which is causing our documentation wkt image generator to not able to
>>> compile and thus not rebuld autogenerated images. On top of that I
>>> discovered my built packages for shp2pgsql-gui and I believe
>>> shp2pgsql/pgsql2shp now have a dependency on GEOs Which while not
>>> absolutely horrible, is not ideal either.
>>> Thanks,
>>> Regina
>>> http://postgis.net
>>> postgis-devel mailing list
>>> postgis-devel at lists.osgeo.org
>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
